| Message |
:Also, I would try a different compression gauge. I have several, no two read the same. I was going to mention WOT, but i see you did that. Of course, a REAL indicator is a leak down test... I might consider renting the leak down testor ( they are expensive) before I pulled the motor. If you still werent happy, you would have some ammo to back to the distributor with.
